Importing 3ds Max files to Rhino with materials?
Hi
Is it possible to Export 3ds objects with their Vray textures to rhino?
I have already tried but I manage to export the object only without the materials.
I even used Obj,fbx,3ds,Dwg formats and neither one was able to export the textures.
I am using 3ds Max 2022, Rhino 6, Vray 4 for rhino
I can’t do it right away, but I believe if you export a obj file from 3dsmax along with a corresponding .mtl file, it will import the obj file into Rhino with the textures correctly mapped as well. I think you’d still have to set up other characteristics of the material in Vray for Rhino like Glossiness, bump, etc.
You can’t do it directly, on per-object/per-material basis. However you can export a .vrscene file from Max and import it as a V-Ray proxy in Rhino. You will get the all the geometry + materials and optionally lights as a single entity in Rhino.
Importing a .vrscene into native Rhino objects is currently under development
:fire: :fire: :fire:
HI @Nikolay , just curious if we’re able to now export 3dsmax files and have the separate layers show in rhino? or will i need to export them by layers/materials.
Kind regards,
Liam
