Hello, I’m finally getting around to trying to deal with an issue I’ve had for a few years. I purchased some .OBJ and .STL models of people in different poses to put in my presentation renderings. They almost always are imported as a mesh which I then convert to nurbs using the MESHTONURB command. This new polysurface can be switched to different layers, however that polysurface will only show up as a dark gray, no matter what the material is assigned to the layer.
Can someone explain to me what is causing this and how I can rectify it if possible? I feel like I’m just not checking the right setting parameters. Any insight would be greatly appreciated.
I’ve attached the Rhino 7 file with some of the people models in it.
squiggle 6_forum question.3dm (6.9 MB)
