If I do this, it gives me an error message. But when I import the data after reprojecting it to WGS 84 it imports fine with the same setup (non-trimmed). Though the projection causes the data to skew, which isn’t the case in QGIS. Does Heron handle EPSG:3003 Monte Mario natively?
Hi @Intuos ,
Can you try updating to Heron v0.4.0 in the package manager? This latest version introduces the SetSRS component so that all Heron components work with a common SRS, such as EPSG:3003.
Thanks @Brian_Washburn! You are a life saver. Amazing update, it works now, awsome! Finally, I don’t have to do any workarounds to pass GIS data to GH.
