Import .ifc frome Rhino 8
Hi, I’m looking for a plugin for Rhino 8, in order to import .ifc files.
Does any free plugin exist for it ?
Thanks,
J
Three not-free plugins come to mind for importing IFC’s to Rhino:
I think all allow for free trial/test period for your immediate needs.
For a free plugin, Speckle comes to mind, as they have at least had the option to import IFC’s on the cloud end. Unfortunately I could not find it anymore…? @idid
Hi @Koempgen,
You can give BEAM IFC a try! It’s a plugin we’ve developed to streamline IFC workflows in Rhino 7/8. It supports both IFC2x3 and IFC4, with options for importing as references or directly into your model. Layers are neatly structured by IFC classes, keeping everything organized.
Check it out here: BEAM IFC. Let us know if you have questions!
Best,
The MKS DTECH Team
IFC upload is still available for Speckle, and we are about to launch a massive reliability and performance boost that’s more tolerant of the junk IFCs produced by various apps.
It’s available as a file upload or drag and drop into a model.
@Jonathon_Broughton
There seems to be 100MB limit on the IFC file size.
Can this be changed somewhere?
Hi, I tried to export a model, but it seems that it does not allow me to export .ifc for my model, maybe to many objects (it’s not very complex):
Hi Toni, it seems that GeometryGym works to import .ifc files. Do you know if it’s possible to export .ifc with it ? I don’t manage.
Beam seems to be limited in a certain number of objects.
Thaks !
Jérémie
Hi @Koempgen,
Yes, the BEAM LITE version has a limit on the number of objects that can be exported, as indicated in the dialog.
We’d be happy to provide you with a trial version so you can fully test the new import and export capabilities. Note that imports do not have any object limits.
Feel free to reach out at info@mksdtech.com to arrange a trial!
MKS DTECH
VisualARQ is only IFC 2x3 for the time being (23.09.2025)
You can always throw your model into Blender(BIM) as an IFC file (pick your flavor of IFC, it’ll work). Now, let’s be honest, there’s no magical “Rhino–Blender Bridge” plugin that beams your model across the software universe in one click. Instead, we’ve got a small toolbox of tricks.
If you’re after something sturdy and reliable, Speckle and the Rhino–Blender Exchange (RBE) are your best friends. They keep your geometry looking sharp and help maintain accuracy, so your model doesn’t arrive in Blender looking like it went through a blender.
For simpler situations, you can stick with the good old file-based transfers: export from Rhino as OBJ or FBX, then drop it into Blender (or the other way around). It works, but think of it as the budget airline version of travel, you’ll get there, but don’t expect champagne service or a smooth ride every time.
So, while there isn’t one single “golden bridge” between Rhino and Blender, there are enough pathways to get the job done. The trick is picking the one that keeps your geometry happy, and your sanity intact.
Hi Jérémie,
Did you have any luck exporting IFC with Geometry Gym? In rhino, it’s best to use layers to classify the model and define a spatial structure as outlined here, Using Rhino IFC Layers | Geometry Gym
In grasshopper there is a comprehensive set of components to generate attributes, properties and relationships in a more comprehensive manner.
If you are having problems, please reach out.
Cheers,
Jon
For exporting to IFC, please try Endpoints.
For more detail visit: EndPoints
For import please write a email to endpointsonline@gmail.com it is wip and I will be happy to help.
Best
Ondrej
