I would like to import a DWG drawing done by an civil engineer. The problem is while importing Rhino is skipping some important elements, in this case height point information. When I open this in a DWG viewer I can see it:
unfortunately this DWG viewer does not let me export anything… of course it is Autodesk…
can somebody suggest an nice alternative for opening DWG wich is more capable than Rhino ? I would be OK to pay a reasonable amout (<150€).
Hi @walther,
It is probably not part of a “default” .dwg format.
Maybe to create that elevation, you need Civil AutoCAD, Architecture or similar.
Can you attach a .dwg with one of those elevations only?
