Hi all,
As the title suggests, I’m trying to import my dwg file from Autocad Architecture into Rhino, however only linework shows up. Is there a way import the 3D elements eg. walls, windows and doors to Rhino as well?
Cheers!
Hi all,
Cheers!
usually that should not be much of a problem, only if you exported to an ancient version of dwg
otherwise maybe the viewport is set to line drawing and automatically shows it only as lines.
