Hello
I have problem with importing styles which I have just downloaded from food4rhino
I had unblocked files after downloading
I work with VA ver. 2.12.0.15409 -(2021/12/21) and rhino 6
Thanks a lot for any help
Michał
Hello
Michał
This .val file was probably saved using “Rhino 7” format. You should contact the style developer in Food4Rhino so he can re-save it using “Rhino 6” or even “Rhino 5” file format. This option is available in the _vaStylesExport options dialog.
Enric
@39herman I’ve uploaded a new .val file to that style, which is compatible with Rhino 6: Bifolding door & window | Food4Rhino
thank you a lot
