Hi. I’m looking to create some custom window and door styles and am searching for some assistance.
This may be a question for F. Salla or one of the VA team?
Here’s a sketch from an Architect of the doors/windows I’m wanting to model:
The bay window on the left is a full window wrap around so the window wraps around the corners. I’m not sure if this will be possible with a window style or not?
It seems my way forward may be to create custom styles from Grasshopper definitions.
Before giving this a go I wanted to find out if there was an example I could use as a template? On Food4Rhino there is a style by F. Salla : Door Style at Food for Rhino
However the vaStylesImport command leads to an ‘unsupported file format’ error. - I assume because the file is a Rhino v7 compatible file format only, not v6?
Is there any chance a version for v6 could be made available or I could be given the original GH file to work with as an example? From that I figure it will be easier to build my own custom style. For reciprocation I’d be happy to share the styles in Food4Rhino.
Any help/guidance appreciated!
