Image Sampler on Spiral Lines
I am trying to make a pattern for CNC cutting using image sampler on spiral lines.
From a test that I made, it looks like the value for the image is not correct with the value for the point. See image below:
I have searched for this topic, but couldn’t find it.
Attached is the gh file.
I would really appreciate your help!
Cheers!
Z2019.11.20_spiral test.gh (1.6 MB)
Image sampler expects points with X and Y coordinates between 0.0 and 1.0. You could change it inside image sampler but I usual keep it default.
Instead of fixing your code I’ve made my own example:
spiral_image_sampler.gh (286.8 KB)
2019.11.20_spiral test_re.gh (1.6 MB)
Hi Lukas,
I got it! Thanks for your help!
Cheers!
Hi @HS_Kim,
Thanks for your help! Finally can’t wait do some experiments with CNC tomorrow!
thank mate!
some fun test with the script!
awesome, how are you animating this in grasshopper?
Hi @GHwiz,
I just used timer and connect to item list to select the mesh.
see attached:
2019.11.22_spiralraster.gh (1.1 MB)
