Hi
I wanted to alert a bug occurring when the output scale is tiny.
It often happens when nested blocks, coming within a dwg file.
Open this sample file.
DIM_FONT_SIZE.dwg (29.4 KB) -
Export as illustrator with something like : preserve model scale: 69 mm = 1 mm.
You’ll have such tiny DIM text that they will be converted to _FontMT 0.0 Tf ( _ArialMT in this case), and this is the bug. -
Open the drawing with illustrator (cs6 in my case). Illustrator will prompt an error.
Illustrator which minimal font size is 0.1 can’t deal with 0 size fonts.
Font sizes should not be set under 0.1.
Once converted to 0.1 , illustrator read the file without problem
