I’m new to Rhino so maybe I’ve missed a way to do this but…
It would be helpful if the name of the active Cplane were displayed somewhere.
I’ve created several named Cplanes with origin at 0 but slightly skewed from the default plane. When I go to a viewport, I cannot tell from the display whether I’m still seeing a named Cplane or one of the defaults.
Hi BoxJoint - No, I do not think you are missing anything - there is no good way to see the current plane’s name. A sort of partial workaround would be to find the plane and select it in the NamedCplane list and it will show you a little XYZ triad at the origin of that plane… but that is not a lot of use if the planes are all in the same location and not very different from one another.
This would be a much appreciated feature. I prefer to keep them independent depending on viewport and when I am in a hurry it’s too easy to mirror something across the wrong axis, etc. So I find myself “making sure” by specifying when a quick glance at the display would often be all that’s needed.
