I want the wave to be different for each layer
I want to create a wave like the one in the photo above and have the wave change shape depending on the z value, but I can’t seem to solve the problem of the z-axis being connected to each other. I’m attaching the file and photo. If you know of a solution for this phenomenon, please help me.
Maybe clarify this?
I’ve baked it, and it looks like this.
ok…and that bake is what you want?
*or this?
No I want to have a different wave shape on the surface that is generated for each z-axis.
I sense the description and images shown are evolving with this conversation :stuck_out_tongue: so I’ll just point out the possibility of ‘tweening’ curves to then get surfaces:
*Furthermore: I guess you don’t necessarily have to generate the surface from points at all and simply form curves from the points then end up lofting - I simply used what you had
Cheers
That’s exactly what I’m thinking!
Thank you!
