I have tried [Mesh BooleanSplit] but the command box says “BooleanSplit failed” also.
Hans.3dm (4.0 MB)
The green layer are the cutting objects and everything else needs to be cut
Hans.3dm (4.0 MB)
Hello - a couple of things - some of your objects are open - that will not work here:
The cutters should extend right through
The vertical cutter can be all one surface - Join and then MergeAllCoplanarFaces
Fix those to start with…
Okay I have done the steps, then tried BooleanSplit again with another file because that one was just messy. Not the result I wanted, I tried mesh Boolean split and it turned out like this.
Hans.3dm (471.6 KB)
I have also had weird behavior from BooleanSpilt, which I’ll link here in case it’s related and/or helpful:
Using Split as an alternative to BooleanSplit leaves objects open, and not always in a place that can be seen to be noticed and fixed, which creates its own downstream problems to troubleshoot.
