Any Ideas why this won't boolean split?
Hi.
Its a closed polysurface that won’t boolean split using a cut plane.
Says they do not intersect ?
Cheer’s
Glennproblem.3dm (392.4 KB)
The cutting surface is open?
Re-drawing the plane, solved it for me.
-Tom
Hi Glenn - that worked OK here - what Service release of Rhino are you running?
Hi Pascal, Running 5.2.1.
So this model is taken from a project I’m working on that somebody else has started.
When ever I take over someone else’s project I always duplicate it and keep the original as a source to go back to.
The original file booleans. Both the duplicate and the exported Problem file that I uploaded don’t.
Hope that helps
Glenn
Hi Tom.
thanks for that but still no joy.
Used cut plane. Extruded curves, created surfaces etc.
Still nothing
Hi Glenn - looking more closely, and on a Mac this time, I see that it does fail… I’m checking into it. It looks like the curve of intersection with the plane is open.
http://mcneel.myjetbrains.com/youtrack/issue/MR-2813
Thanks Pascal.
Hi Glen
It worked just fine in Windows - R5.
Costel
