I need help for viewport, rendered
where the fault when the screen is not displayed the environment? Does not change the studioa or interior or sky ? only when you click on the toolbar blue balls . So I can not spin the model in the state . aspect is the viewport .something must be wrong settings or something else
you know these beginners …
Hi Harri - set up like this should work-
Also, the material on the objects must have some reflectivity:
What’s wrong when the screen does not appear in the environment? Does not change the studioa or inter or sky ? only when you click on the toolbar blue balls . So I can not spin the model in the state . At the beginning it was seen but I can not get it to appear any longer . something must be wrong settings or something else
but i need help
ok, i try this . thanks
it did not work. material change yes model but not in the environment.
Hi Harri- can you please post your model? I’ll see if I can get it set up - I am not sure I understand the problem…
that fine
