I keep getting this message 1. Solution exception:'NoneType' object has no attribute 'NumberRows'
I am using gismo, I don’t know if I installed something wrong or missing something to install. I don’t know what I am doing wrong or how to fix this, please help!
Hi David -
You now need an API key to be able to download the terrain.
That’s not possible with the 2017 version component that you have installed and you will need to update that.
For more information, see:
FWIW, @djordje - https://portal.opentopography.org/lidarAuthorizationInfo is down at the moment - but perhaps that’s just a temporary thing…
Thanks! it was exactly just that! I decided to switch to urbano instead, it was a lot easier that way
Hi @david.ortiz-de-la-to ,
Wim is right, you need a free APIkey to generate the terrain with Gismo, since this year.
@wim ,
Thank you for the help. On my side, opentopography is working. Yes, probably it was a temporarily shutdown.
