I have an issue after joining 5 curves and I only get 1 curve segment added to selection
RHINO 6 SR 29
join !!.3dm (584.8 KB)
What command were you using when you tried selecting the curve and only one segment was selected?
I was just trying to select to joined curve
Somehow you are doing a sub-object selection instead of an object selection.
Did you just move the cursor over the curve and click, using the Gumball, or something else? If I move the curvsor over the curve and click the entire joined curve is selected. I don’t use the Gumball so I don’t know how it works.
I know how to select sub object but the problem here is after joining all curvea it became another curve segment again and it’s weird
I hate my life
this problem again because of percision and tolerance
