I tried different DWG files and it happens every time the grid disappear and I cant make it appears again (tried Fn+F7 and show grid command and no luck )
Hello - when the DWG file comes in, it may not be near the default CPlane at all - I’d check that first. (i.e. the grid is out of view so turning it on and off does not change anything in the current view)
Yes, I created a cub at the center and tried to activate grid and turf it off But I can’t see changes -No grid-
Hm - just to be sure - if the grid is showing and you import a dwg, the grid disappears, and can not be restored, is that correct? Is this true in a default wireframe viewport?
