hi,
I don’t know why, my grid and axis disappear when I import / insert a dwg drawing…
I’ve try all the things mention in THIS similar post without success…
any idea ?
best,
-CC
hi,
any idea ?
best,
-CC
Hi CC - it may be that the Zoom to the imported objects is pulling the view away from the Cplane. DWG import zooms to the objects…
Hi pascal,
I tried to move the whole drawing to location 0,0,0… nothing change…
Hello - is the scale of the import such that the grid would normally show (i.e. not be tiny)? What happens if you press the F7 key, anything?
We will need the file to figure out out.
I suspect the model is not near the coordinate origin, or is much bigger so the existing Grid is either too far away, too small, or both.
Thanks pascal and John. I appreciate the fast help. Grid was too small… Problem solved
-CC
