Hi, I’m trying to use the Justified Text component, I input the size and font but when I bake it, it creates a text with default height and font, I’m not sure if this is a bug.
Thanks
Test Human.gh (17.3 KB)
Thanks
I’m experiencing the same issue.
Having the same problem, but haven’t found any solution yet
Hi - I’m not seeing that on my system here on Rhino 6 and Rhino 7:
… but note that the font table on your machine most definitely is not the same as on my machine…
So if this is something that you can only reproduce with a specific font, you’ll need to also provide that information.
Are you able to post the working gh file? I have the same issue of text size just baking to whatever current rhino text style is… same result for Elefront and Human. Any input text size is overridden.
