Hello all: I am using a HP T250 Plotter. It worked fine in Version 7 but will not plot anything In Version 8. As a work-around, while in Ver8 I can save my drawing as a version 7 then run Version 7 and open the drawing and the plotter works normally. Anyone having similar issues with Ver8? Thanks.
Hi @Paul_Beaty
There have been many print changes in v8 and several regression fixes. I’m not certain which service release of v8 you happen to be using however, please make sure you’re trying to print from Rhino 8 SR10 and see if you still encounter the issue. If so, let me know and we can take a deeper look.
Hello, Yes I believe have the latest release: Version 8 SR10
(8.10.24219.11001, 2024-08-06)
Thanks for your help.
Plotter problem was fixed when I downloaded new drivers for HP plotter from the HP website. Just letting Windows check for new drivers, I’d gotten the message that all was up to date but when I went to HP’s website, I found that there were in fact newer drivers. Plotter now works fine in Version 8.
