How Warp stl to surface
Hi, how can I Warp stl to surface.
Thanks
You might be looking for the _ApplyMeshUVN command.
Hello - if you did not sort this out, can you post your file?
Test Warp.rar (5.8 MB)
Hello - for some reason 7Zip does not like your RAR file - can you zip it and resend? thanks
Test Warp.3dm (11.1 MB)
Hello - something like the attached, maybe?
Test Warp_maybe.3dm (2.8 MB)
Thanks, how did you do that .
Hello - well, it is a bit tedious… I removed all of the mesh that does not ‘fit’ by turning on the mesh points, and using SelBoundary in Front using the red perimeter curve (DupBorder). Then InvertPt and delete the outer points.
Then I copied the target surface, and untrimmed it and flattened it to the mesh. (this is on its own layer).
Then FlowAlongSrf the mesh from the flattened to the 3d surface.
Note your surface gets a bit messy near the pointy end:
