Hi I want to be able to view surfaces with transparency in a Layout, is this possible?
At the moment I can only view the surfaces (with transparency applied through material) as a wire frame.
Can someone point me in the right direction.
When you activate a detail on a layout, you can set the display mode for that detail. Setting that to Rendered should allow you to view surfaces with transparency.
