How to use the value of Open Nest to make my cutting line layout denser and make full use of the space
I use Open Nest to typeset my curves, but why are they arranged so sparsely? How can I adjust them to make full use of the typesetting space? And I want to arrange these four rings together, but I don’t know why, it just doesn’t work. I think those cases can be operated like this
627bc6460de99a0063a208a4d8fa34e
参数条鱼open nest.gh (47.5 KB)
here is a very well-done and super explanatory video on how to use Open Nest: OpenNest: Introduction | #01 Nesting Objects with Text in Rhino - YouTube
at minute 6:00 it explains what the “rotation” value does:
in simple words, the number of rotations is the division of the full 360 degrees angle in which each piece can be placed: if you use value 3 like in your picture, then each piece will be tried “as it is”, or rotated 120 degrees, or rotated 240 degrees, nothing more nothing less
if you are looking for a wider range of rotations, you can just insert (for instance) 36: that way you will get 36 possible increments of 10 degrees each one (this increase of possibilities will of course reflect on the calculation time)
I adjusted the value of Rotation to 360, why the typesetting method is still not ideal, there are many gaps
I think you are looking for true shape nesting or equivalent.
I suspect you will only get that in a paid solution.
is this closer to what you were expecting?
参数条鱼open nest_Re.gh (75.4 KB)
