This pic looks like a drainage flow diagram.If so, you may simply just need to transform a pic into a 3D topo based on the grayscale, and do a flow simulation in kangaroo, of which both tutorials would be easily found on youtube.
Thank you. Could you tell me how to search on youtube? What are the keywords? I tried, but I couldn’t find them.
thank you
Thank you for your reply. I want to construct a light blue curve by connecting points, the kind in the pattern
How to draw the curve in the picture with grasshoppers?
There are hundreds (thousands?) of curves in that image. I don’t think Image Sampler will help.
Thank you very much! Next, I’ll process the picture first.
Surely because the default threshold is not good for your image.
20230226_image thinner.gh (7.4 KB)
Play with the slider, it must work better.
Because I am not familiar with C#, I bother you again. Thank you very much for your answer. Thank you!
So the solution is a black box that you can’t understand or modify…
I sincerely hope you have no plans to become an engineer.
There is still a long way to go, so I have no plan for the time being. ![]()
