I’m wondering if there is a way to switch between a “fullscreen” viewport, or maybe the corect terme is maximized viewport.
In windows I’m doing it with the shortcut ctrl+tab, but it doesn’t work in my mac version. I also try the nextvieport option, but after a few switch, it goes back to the forth viewport option.
So if you a a solution, I would be really thankful !
Best
Damien
(I’m using the 5.3.1 version of rhino in macOS sierra, on a macbook pro)
NextViewport switches sequentially through all views and cycles them just like in the windows version. i am not sure anymore if i activated that myself since i use the middle mouse button for this, but in just in case go to the rhino preferences -> commands -> customize, then in the search field below you search for next viewport and assign the short cut, if its not there yet you can also make one yourself by pressing on plus and name it so with the command in the script field.
Yes I’m looking for an keystroke only method.
I try RchardZ proposal, but I can’t stay in a maximized viewport for more than three switching. Then it automatically goes back to the four viewport view.
I’m also trying to ajust the shurcut and mix it with maxviewport, but without success up to now.
I’ve done this by assigning following hotkeys and it works really well:
“§” - toggle between 4view and maximized
“1” - maximise perspective
“2” - maximise top
“3” - maximise front
“4” - maximise right
You can do this by going to “Rhinoceros” > “Commands” > “Customize…”
I suppose you can assign hotkeys to manipulate the view in addition to changing actual viewports. Try by searching for “set view” or similar…
Regarding modifier keys, yes. For me personally just §,1,2,3,4 works fine since I don’t use any functions that begin with those characters, at least for the time being…
Hi Ties
have you tried this, more then one cycle? …
the thing is that currently, [latest WIP] it work fine though the 4 v. ports, but then [as mentioned earlier in this thread]
it gets bogged down in the 4 view button and from there the command will only circulate the active port within the 4 view.
Hi Akash,
I do not use the 4 small viewports in one window very often. When I use it, I don’t mind to click the button top left to switch from maximized viewport to small. Once back in maximized, I use my shortcut again to cycle through them.
Do I understand it right when I say you’re looking for a way to include the 4 small viewports within the cycle of maximized vieports?
Hi Ties
i may have not been clear enough with my english,
i too rarely use the 4 small views. what was said is that when you are in max view, and cycle with the shortcut: once one cycle is through, the command jump into the 4 view condition and get stuck there. only circulating active view within the small 4…
don’t you have the same issue on your machine?
As Akash explain, the cycle end after a turn and get block in the 4 small views…
then I wonder if it’s a bug or a possible configuration.
So by know I’m using the numpad to switch between views, as it has been suggested by stefannysten, so thanks !
It’s an alternative, I wasn’t using maximise, but only view top, witch was creating some troubles then with ctplanes, and différents viewports.
Akash, Damien1,
Strange, I don’t have this behaviour. For me the small viewports are not included in the cycle.
So it sounds as if it’s a configuration issue…?
Hi Damien
the limitation i have with the keys shortcuts is that they only work for the default views.
and if i have for example Left view, i’m unable to assign a key shortcut to it.
perhaps you know how to?
