I want to draw a handrail (Hollow section) of a spiral staircase.
Sweep1 just allow curve to open polysurface.
How can I do it?
Thanks
Hello - if the ends are planar, and closed in the ‘around’ direction, use the Cap command.
What I wanted is to sweep to form a solid barrier as attached. Furthermore, the end part of barriers to be vertically flushed.
Anyone can tell
Thanks
Could you tell me how to built up 18 planks (20 degree each in polar helix) to match the barrier as attached
Thanks a lot.
Planks.3dm (1.0 MB)
Polar array and use a z axis step offset
your hand rail is deformed instead of sweep1 copy your red curve (helix) to center of hand rail and use “pipe” command.
thanks @robinp i didnt know that.
Yes, I did.
Sweep in Autocad is OK without deformed
