Hi all,
I have a small routine in Python that I would like to implement using the Hoopsnake component. It is a subdivision process that recursively splits a surface in half until a minimum area is reached.
The main subdivision step looks like this:
However problems occur when I try to implement this step inside a recursive procedure:
- I don’t understand how to correctly connect the input and output to the Hoopsnake component
- for some reason the splitting curves seem to get scattered around the original surface (most probably because of the improper connections I made)
- I can’t seem to find how to retrieve the resulting split surfaces
Could you help me figure out how to correctly use the Hoopsnake component for this simple recursive task ?
Recursive Subdivision with HoopSnake.gh (22.0 KB)
