How to space out the edges of the sheets
Hi, I am prepping a file for CNC cutting the contours.
I am trying to maximize the sheet size which is about the machine’s cutting dimension. Therefore it is better to keep the contours within a sheet with some spacing in between the edges of the sheet. I can control the spacing between each contours using the spacing input. Is there a way to achieve this? Thanks!
GH_3.gh (26.6 KB)
QuadRemesh_nurb.3dm (6.4 MB)
Create a smaller sheet, in your case 1210 and offset the resulting sheets by 5. This is how I do myself.
yes! I thought of this as well, seems like a good solution!
