How to Sort Block Instances by Name in Grasshopper?
Hi everyone,
I’m working with block instances in Rhino and Grasshopper, and I’m trying to sort them by name inside Grasshopper. I already have a list of block instances referenced into Grasshopper using Elefront. These blocks have clear names like 1FT-000130-00, 3WO-1100020-00, etc.
However, when I bring them into Grasshopper (via Block Instance → Block Definition), their order seems unpredictable. I want to sort them alphabetically (or alphanumerically) based on their block definition name.
Questions:
Can I use Sort List or Sort Text with those names to reorder the geometry accordingly?
Any advice, examples, or links would be greatly appreciated!
Thanks in advance :folded_hands:
Use this…
And set the K input to Model Block Instance / Instance / Definition / Name
You might also want to try Model Block Definition / Name
Why don’t you try it yourself?
