Hello
I would like to know if there is any way to set a version number in a plugin’s dockbar?
To have visual control of which version the user is using.
Hello
Good morning @Luciano_Luiz_da_Silv,
If you are using C# you can set the version in your .csproj
which will be compiled into the output .rhp
assembly.
<PropertyGroup>
<Version>1.0.0</Version>
<AssemblyVersion>$(Version)</AssemblyVersion>
</PropertyGroup>
You can then access this from within your code like so
internal class MyClass
public Version GetVersion() => typeof(MyClass).Assembly.GetName().Version;
– cs
I’m using c++ to create my plugins.
Something like the image
In your dockbar code, you should know where you’re setting the caption. Just format the string to include whatever info you want.
– Dale
Hi Dale,
Yes, this is perfect, but I think there would be something like a counter, each time the plugin was compiled this version text would be incremented…
