I have multi object are polysurface type. I want select the top surface in polysurface.
One method may be to compare a face normal to +z axis:
import scriptcontext as sc
import Rhino
guids = rs.GetObjects('select objects')
up = Rhino.Geometry.Vector3d.ZAxis
for guid in guids:
brep = rs.coercebrep(guid)
robj = rs.coercerhinoobject(guid)
for face in brep.Faces:
# Use top-center bounding box point to sample face
bbox = face.GetBoundingBox(Rhino.Geometry.Plane.WorldXY)
top_point = bbox.PointAt(0.5, 0.5, 1)
# Find closest u,v point to top-center
closest_point_ok, u, v = face.ClosestPoint(top_point)
# Find face normal at closest point u,v coords
normal = face.NormalAt(u, v)
# Calc angle between up and normal vector
angle = Rhino.Geometry.Vector3d.VectorAngle(up, normal)
degrees = Rhino.RhinoMath.ToDegrees(angle)
# If angle is less than some threshold, select it
if degrees < 45:
robj.SelectSubObject(face.ComponentIndex(), True, True, True)
Another method may be to use the bounding box center for each face and select the highest one.
Guess it will depend on how ‘normal’ your polysurfaces are to the example file.
