Hello everyone
I’m trying to develop a simple python plugin which draws a sort of “halo” around the bottom surface of a polysurface ( I’ll use that to avoid nesting objects too close to each other )
import Rhino
import scriptcontext
def Halo():
OBJ = rs.GetObjects("Select objects to nest:", 16, False, True, True, True)
if not OBJ: return
for ObjId in OBJ:
Surfaces = rs.ExtractSurface(ObjId, 0, True)
for SrfId in Surfaces:
Edges = rs.DuplicateEdgeCurves(SrfId)
rs.DeleteObject(SrfId)
JoinedEdges = rs.JoinCurves(Edges)
rs.DeleteObjects(Edges)
for EdgeId in JoinedEdges:
col = rs.CreateColor(255,0,0)
Direction = (1000,1000,1000)
OffsetEdges = rs.OffsetCurve(EdgeId, Direction, 20)
rs.DeleteObjects(EdgeId)
for OEId in OffsetEdges:
rs.ObjectColor(OEId, col)
Grp = rs.AddGroup()
rs.AddObjectsToGroup([ObjId, OEId], Grp)
if __name__=="__main__":
DoHalo()
This won’t work because the surface “0” is not always the bottom one, as I could have rotated the objects. Question is :
How can I select the surfaces facing down or, at lest, the surfaces laying on the C plane ?
Or even better, is there a way to select the largest one between the top and bottom surface ?
emm…About “I’ll use that to avoid nesting objects too close to each other”, I don’t see a code related to transform,about finding the collision range of Breps ,I will try this way:
Thanks everyone for the help, I ended up using the Meshoutline method with the top view selected.
For some reason it don’t accept polysurfaces as input in a script, so I had to work around it using the Command function and selecting\deselecting things through the loop.
Seems to work pretty well tho
import Rhino
import System.Guid
def Halo():
rs.EnableRedraw = False
SelObjects = rs.GetObjects("Seleziona le polisuperfici:", rs.filter.polysurface, False, True, True, True)
HaloOffset = rs.GetInteger("Valore dell'offset per l'halo:", 10, 0, None)
if not SelObjects: return
if not HaloOffset: return
rs.UnselectAllObjects()
scriptcontext.doc.Layers.Add("Halo", System.Drawing.Color.Red)
direzione = (10000, 10000, 10000)
if rs.MessageBox("Vuoi spostare tutto sul piano C?", 4 | 32)==6:
#Moves everything on C plane, if needed
for Obj in SelObjects:
bb=rs.BoundingBox(Obj)
if bb: rs.MoveObject(Obj,rs.coerce3dvector([0,0,-bb[0][2]]))
rs.CurrentView('Superiore')
# Switch view to top
rs.SelectObject(Obj)
rc = rs.Command("_MeshOutline", False)
if not rc: return
Crv = rs.FirstObject(True)
Halo = rs.OffsetCurve(Crv, direzione, HaloOffset, None, 2)
rs.DeleteObject(Crv)
rs.ObjectLayer(Halo, "Halo")
Group = rs.AddGroup()
rs.AddObjectsToGroup([Obj, Halo], Group)
rs.EnableRedraw = True
Halo()
