Is there a command or script to select the end and starting control points of selected curves?
Hi Joaquin -
! _SetRedrawOff _SelU NextU NextU PrevU InvertPt _SetRedrawOn
for a surfrace:
! _SetRedrawOff _SelU SelV NextU NextU PrevU NextV NextV PrevV Invertpt _SetRedrawOn
Of course if other objects have points showing, this will not work well - if that is the case, a script is needed, I guess.
Thanks a lot Pascal!
That was fast!
Joaquín
@laborda - see if this is a bit more versatile -
To use the Python script use RunPythonScript, or a macro:
_-RunPythonScript "Full path to py file inside double-quotes"
