hi guy’s
I use a way to soften the edges of the grid of curves on The rhino. But every time I manually select some control points that are close to the line specified for the edges. i given my little information on GrassHopper, and python
I can’t find a solution.
Note: I am not good at writing in English. The wording may be unclear.
thanks
You can slightly Offset your curve inside and then select all the points outside using SelBoundary; don’t forget to set the SelectionMode option to InvertCrossing or InvertWindow.
