Rhino 8 SR33 Mac - Layout printing not true to scale
I have spent several hours trying to solve this issue and have narrowed it down as much as possible. At this point I believe either I am missing a Layout-specific setting or I have found a bug in Rhino for Mac.
Environment
Rhino
  • Rhino 8 SR33
  • Version: 8.33.26188.13002
  • Commercial License
System
  • Apple Mac (M4)
  • 32 GB RAM
  • macOS 26.5.2 (Build 25F84)
Problem
Printing from a Layout is not true to scale.
Printing the exact same geometry directly from the Model View is accurate.
Test model
To eliminate any model-related issues, I created a very simple test.
  • Square
  • Size: 150 × 150 mm
  • Units: Millimeters
Test 1 – Printing from Model View
Procedure:
  • Front View
  • File → Print
  • Print Area: Window
  • Scale: 1:1
  • Save as PDF
  • Print the PDF at 100%
Result:
Measured print:
149.5 × 150 mm
This is essentially perfect.
Therefore:
  • Geometry is correct.
  • Printer is correct.
  • macOS PDF printing is correct.
Test 2 – Printing from Layout
Procedure:
  • Open the Layout
  • File → Print
  • Print at 1:1
Result:
Measured print:
Approximately 132 × 132 mm
The same file, the same geometry and the same printer produce a significantly smaller print when printed from a Layout.
Additional observations
Changing the Rhino print mode changes the result:
  • Vector output → approximately 132 mm
  • Raster output → approximately 163 mm
Neither mode produces the expected 150 mm.
macOS Print Settings
Verified:
  • Scale = 100%
  • “Fit to Page” disabled
  • Correct paper size (A2 Portrait)
Additional tests
The issue is reproducible on three different printers.
Printing from the Model View always produces the correct dimensions.
Only Layout printing changes the scale.
Expected behaviour
Printing from a Layout at 1:1 should produce exactly the same dimensions as printing directly from the Model View.
Files available
If required I can upload:
  • Rhino 3DM file
  • PDF generated from Rhino
  • Screenshots
  • Photos with ruler measurements
  • Complete SystemInfo
Question
Is this a known issue in Rhino 8 for Mac?
Or is there any Layout-specific setting that could explain this behaviour?
Thank you very much for any suggestions.
@Friedrich_Schweiger pls upload a file that shows this behavior.
In a quick test here I cannot reproduce the behavior you’re describing
Hi Gijs,
Thank you for your quick response.
I have attached a minimal test case:
  • LayoutPrintTest.3dm
  • LayoutPrintTest-Layout.pdf
  • LayoutPrintTest-Modell.pdf
The square in the model measures exactly 150 × 150 mm.
The important point is that the two generated PDF files already show the square at different sizes.
  • The PDF generated from the Model View shows the expected size.
  • The PDF generated from the Layout shows a larger square.
Therefore, the scaling difference already exists in the PDF output before anything is printed.
I hope this helps to reproduce the issue.
Thank you!
LayoutPrintTest.3dm (46.1 KB)
LayoutPrintTest-Modell.pdf (1.2 KB)
LayoutPrintTest-Layout.pdf (1.2 KB)
In your layout, in order get your output 1:1, the details added to that layout need to be 1:1 also.
Right now, the detail you added is 1: 0.383
Hi Gijs,
I think I now understand which panel you were referring to.
If I remember correctly, an older version of Rhino for Mac also displayed the Detail View properties, including the scale values.
However, in Rhino 8 SR33 for Mac I can no longer find that panel.
The Properties panel is open, but when I select the detail viewport, the “Detail View / Scale Value” section shown in your screenshot does not appear.
Could you please tell me the exact steps to display that panel in Rhino 8 for Mac?
Once I can access those properties, I will immediately check whether the detail scale is indeed set to 1 : 0.383.
To make sure I wasn’t missing anything, I created a completely new document and reproduced the entire workflow from scratch. The only thing I cannot reproduce is the Properties panel shown in your screenshot.
Thank you very much for your help and your patience.
Best regards,
Fritz
To get that, select any detail and run _Properties
Hi Gijs,
Thank you very much for your help.
Your hint about using the _Properties command was exactly what I was missing. It opened the Properties window where I could set the Detail View scale to 1:1.
After changing the scale, the printed output was 100% accurate.
Thank you again for taking the time to help me. I really appreciate it.
Best regards,
Fritz
