Certainly. There are a number of reasons this could be happening, let us know if the 8.19 resolves it.
Thanks! Moving to 8.19 worked
Hi Japhy, I am encountering the same problem with the latest Rhino 8 update, Rhino won’t start because of plug-ins errors, can you please be so kind to send me the previous release version of Rhino 8 Window English? Thank you
Hi Nguyen Khoi Chu,
The current release is 8.22, sending you 8.21. If that doesn’t resolve your issue we should start troubleshooting your plugins.
hi @kamal.dahiya.26 I recommend trying a Rhino repair first. Click Modify
Then in the next dialog choose Repair
Hello, tried.
Even tried the classic uninstall and reinstall.
A manual deinstall might help resolve this.
Did not work, can you pls send the 8.19, cause that version was working fine before i updated.
Pm sent
Hi all. got a similar issue here. Would like to roll back the update since ladybug tools does not work with the latest release. Would be grateful for your help
(Solved. My bad. it was such a clash between pollination and LB manual install)
Hi, having an issue with grasshopper gold after the most recent update on Rhino 8, could anyone send me the download link for the previous version?
Hi Brenda,
What is the issue?
How long has it been since you updated? Any particular version you would like to try? I’m assuming this is windows Rhino.
Hi Brenda, Those are default components. Try a repair install first. Go to Add/Remove Programs and Modify the Install / Repair.
I’ll send you 8.23
Hi Japhy, thanks so much for this recommendation - I was able to repair with no problem.
Having issues with loading custom tools after updating to 8 SR25 (2025-11-10)
Error occured running command “9bdb9d45-c3e0-4759-a8e3-4f0e788e8822” | Python.Runtime.PythonException: No module named ‘traceback’
at Python.Runtime.PythonException.ThrowLastAsClrException()
at Python.Runtime.NewReferenceExtensions.BorrowOrThrow(NewReference& reference)
at Python.Runtime.PyModule.Import(String name)
at Python.Runtime.PythonException.TracebackToString(PyObject traceback)
at Python.Runtime.PythonException.get_StackTrace()
at System.Exception.ToString()
at Rhino.Runtime.Code.Execution.CompileException.ToString()
at Rhino.Runtime.Code.Execution.RunContext.TryWriteException(Exception exception)
at Rhino.Runtime.Code.Code.WriteException(RunContext context, ExecuteException exception)
at Rhino.Runtime.Code.Code.Run(RunContext context)
at RhinoCodePlatform.Rhino3D.Projects.Rhino3DProjectServer.RunAndReport(Command command, IProject project, Code code, RunContext runCtx, InvokeContext invokeCtx)
In 8 SR24 all was/is fine (25-10-08), can you please send me this version
