How to repeat the last command by command?
Hi…,
a customer needs this for a SpaceMouse key. I thought _Enter or _Repeat would do it, but don’t.
Any ideas?
Thanks
Michael
www.flexiCAD.com
Hi Michael - preceding the command (or macro) with * will run it again and again - is that what you need?
Hi Pascal,
I need repeating the last command by a command, like _RepeatTheLastCommand. _Enter doesn’t do it.
What does the * do?
Thanks
Michael
Hi Michael - * just keeps a command or macro going until you stop it -
*Line 0
for example. I do not know if there is an thing that will just run the last run command… I’ll poke around.
@Michael_Meyer - this tiny bit of python may help
if rs.LastCommandResult() == 0:
    rs.Command(rs.LastCommandName())
I am not sure how to make that work in the context you mention - maybe just put that in a text file, saved as Repeat.py and then use a macro in Rhino
! -RunPythonScript "Full path to py file inside double quotes"
Hi Pascal,
thank you for your help. I will wait and see what the customer says.
Cheers
Michael
