Hey everyone. I’m trying to segment an organic curve to segmented polyline but I want it to still have the organic shape. Can anyone suggest me what to tool to use Thankyou! (It would be nice if I also can do it by grasshopper)
are you searching for
_convert
output = lines ?
you can also
_divide (number or length)
_selPt
_CurveThroughPt
(Degree = 1, Curve Type = Control Point)
(technical the result is a Nurbs curve - check with the _what command)
if you need a polyline
_explode
_join
similar approach is possible in grasshopper.
if above does not help - please give more information, a sample .3dm file maybe a scribble / sketch for the desired result and tell us more about the workflow you’re after
kind regards -tom
A) You probably need to provide more information, see this post:
B) Like @Tom_P said, you can subdivide a curve and draw a polyline through the resulting points:
240307_DivideCurve_00.gh (5.0 KB)
