Sometimes I need to take a screenshot of Rhino but when I open the snippingtool the floating viewport and the floating toolbars disappear (which is a good thing in most scenarios) so how do I toggle them to be on visible?
I use the delay function on Snipping Tool
. That will allow you to start a capture, switch to Rhino and have all the floating stuff be visible before the capture is made.
I would make a screencap with Snipping Tool
of Snipping Tool
, but it hides itself for the duration of the capture…
Here a Shift+PrtSc and cropped in Paint
P.S. answer to your question: you don’t - there is no such toggle AFAIK.
Ok, then can you please put it on the wishlist? At least for Floating Viewports?
I use it for Raytracing to ensure a fixed viewport size and then it is nice to have it visible while it calculates.
I use this macro to pop up a new viewport:
! _NewFloatingViewport
_Projection=CopyActive
_-ViewportProperties
_Size
1920
1080
_Enter
Request logged as RH-45656.
learn some every day.
Thanks Pascal!
Awesome! Thanks Pascal
