How to offset a brep?
I want to offset a brep, with the same result as ‘offsetsrf’ inside rhino.
The ‘offset surface’-component does not work with my brep (which is a polysurface).
I know there is a grasshopper plugin to solve this problem, but I want to find a solution without plugins.
Thank you!
Dunno if any plug-in has it but offsetting breps is not so easy (of course you haven’t shown us the brep so who knows) but you can use this C# method here: https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Brep_CreateOffsetBrep.htm
