How to move to absolute coordinates with the move tool
Hello!
Something I thought I knew… cannot seem to find this in the help files.
How would I enter absolute coordinates when in the move tool, but leave out axes that should remain unchanged?
I’d expect something like
,5,
to move to absolute 5 in y, or
10,
to move to absolute 10 in x, leaving y,z unchanged, but move throws the error “unknown command”.
Thanks!
There’s always boxedit in the meantime.
In combination with the Gumball, yes. But ist there a old CAD trick for the Move command?
Hi Eugen - relative coordinates, which is what I think you mean, can be entered with
rx,y,z or @x,y,z
e.g. r0,5,0 r0,0,10
Hi Eugen -
If I want to move this circle so that its center point keeps the current x-value but needs to be on Y=10, I start Move and pick the center as the From point.
I then type .x and select the center of the circle again.
That constraints the movement along the y-axis.
I then type 0,10 to place the circle where it needs to be.
– Reading what Pascal wrote and rereading your original post, it looks like I was thrown off by absolute vs relative…
With this workflow, for the last step, you’ll type 10 and pick the point above or below the current location.
Thanks, guys!
Actually, I did mean absolute coordinates (Relative I know). Pick an object somewhere (not necessarily at it’s bounding box borders), and define one of it’s coordiantes to be at some absolute position.
I feel stupid, but after fiddling around I still don’t understand a few things (must be using the Gumball for too long, and rarely the old cad coordinate syntax)
  • What does .x mean (or .y or .z)?
  • Why do I have to enter 0,10 (or whatever) when the axis is already constrained?
  • How can I do this in a 3d view?
Intuitively, I’d expect entering the coords in the form , , 23 would leave x and y unchanged, but sets z to 23. Obviously this does not work like so.
No worries here, it’s mere interest.
Thanks!
Ah, OK - .x, .y, .z then.
Move > pick move from point.
.y > type 10 and enter.
snap to the move from point to finish. (point osnap will find it)
Look for “point filters” in this Help article. Actually, since you are curious now, that whole section is really helpful.
https://docs.mcneel.com/rhino/8/help/en-us/index.htm#user_interface/accurate_modeling.htm?Highlight=coordinates
Ok, this is what I was looking for!
.x
.y
.z
.xy
… are point filters. After entering one of these, either a value can be entered, or a point be picked, to define this coordinate. Then, a second point has to be picked to “fill in” the other coordinate values (that was the part I stumbled over).
Thanks everyone!
Box edit get’s weird sometimes, especially with a lot of objects selected. Super sad about that.
