Unfortunately, dynamic plan and section in layout still can not be exported as dwg.
I need to export plan views and section views as dwg, but they are basically block so when I import them
in AutoCAD, I’ve lost layers.
Is there any way that I can keep layers created in Rhino an Visualarq in AutoCAD?
Hi @archist97 this looks like a bug, since layer attributes should be preserved in the geometry in plan and section views.
As regards the option to export layouts to dwg, it’s a planned feature for VisualARQ 3. But we are still discussing the best way to implement it. For example, would it work for you to just export what you see in the page layout as a bunch of 2D lines that you import in the AutoCAD’s model space? (preserving layer attributes, of course).
Hi, we are going to fix this as soon as possible and release a new update.
In the meantime, I can send you the last VA 2.11.3 version. I’ll do it through a PM.
Hi.
It looks like 2.11.3 can not keep layers, either.
I’ve tried two methods to convert VA to dwg
Method 1) Exporting VA Plan View directly to dwg
Method 2) Printing Layout to PDF → Import PDF in Rhino File → Save as dwg Layout to dwg - #7 by dbusmire
I could not keep layers with these 2 method.
