Hi you all!
At this moment I’m trying to build a structural facade, with facade openings in Grasshopper. Doesn’t sounds too difficult up to now.
The reference project in this link shows what i try to achieve;
Here comes the difficult part: how to do this (on a double curved facade)?? I’m totally lost in how to do it.
What I want to achieve:
- Create the structural facade (thickness isn’t the most important part for now). >> I did this by creating a loft.
- Create the openings in the facade. These openings should be “random” with a “random” size, according to the idea of the reference project. The size of the openings will be determined using Ladybug, the more radiation, the bigger the openings.
My experience in Grasshopper: Little. Just started using it since a couple of weeks ago at school. Had some minor introduction courses, and try to Google a lot as well. But with this challenge I’m not sure on what to Google and what to search on this forum either.
As a temporary side approach I now used Lunchbox to create triangular panels on the surface, which than creates panels with various sizes according to the amount of radiation. These panels are than the '‘openings’ in the facade.
The file is in Millimeter (large objects) Randomnized facade.gh (515.3 KB)
The facade ‘volume’ is internalized in the gh file. The pattern is created by acitivating the Ladybug components. Above the Ladybug components there is a row of gh components which create vertical lines which than are pulled to the surface; this is the experiment with the repulsion/attractor points. The rest of the deactivated components in the file are other experiments.
How I think the problem should be approached is by looking into removing mass in the structural facade. But I can be completely wrong with this idea.
I’ve tried using Milipede (plugin), TopOpt (plugin), Karamba (plugin), Attractor/Repulsion points (with curves projected on the surface) [http://www.grasshopper3d.com/forum/topics/flow-curve-around-object-in-2d?commentId=2985220%3AComment%3A1800152]. All without any succes which gives the solution I want, or even coming close.
Can anyone help me guiding in the right direction? As in maybe which plugins, what search terms on Google, maybe someone even has an example which I can partially rebuild to what I need.
Thanks in advance!
