How to load .hdr into Rhino environment with Grasshopper
Hi Guys
I am currently exploring the possibility of performing automation rendering using Grasshopper. I am able to import .rmtl and very happy with the result!
l would like to check if there is a way to import .hdr into the scene to make it look better?
Thanks in advance
Chua
This is Import Model Environment:
This is V9 (not sure if it exists in V8). If you own V8 you can try WiP.
Thank you so much! :blush:
@Piotr it is in R8 thankfully:
Hi Michael
I can’t find additional features under my Render tab except these two:
Did you install separate plugins for R8?
Thanks and Best Regards
Chua
You might have to update to the latest release…
Hi Martin
It worked after updating to latest Release.
Thankyou so much!
Best Regards
Chua
Hi @chuachinghong,
What version of Rhino are you using?
You can check in the Help>About Rhino, Help>Check For Updates, or by running the command SystemInfo
I’m on version 8.10 so it’s quite possible you on a previous version that does not have that component added yet.
EDIT:
Nevermind, I see that you solved it with @martinsiegrist’s help
Yeap I am in 8.03.
Thanks for your help :slight_smile:
