I was hoping to start using Hops add-in, but our slightly paranoid sysadmins have disabled network access for Rhino. So no access to the Yak package server.
Can I download Hops somewhere?
Hi Menno -
Do you have access to a machine that isn’t restricted? You could download or install Hops on that one and copy it onto the restricted machine.
There’s more information about Yak from here - Rhino - Package Manager Guides
No, I’m only using Rhino on my work machine, which is restricted.
Hoi Menno -
My question wasn’t restricted to using Rhino. On the machine at work, when Rhino is installed, a utility program - yak.exe
- is also installed. You can use that on a PC that doesn’t have Rhino installed to get command-line access to the server. The details should be in the guide. I’m just not sure if you have access to a PC that has less restricted access to the internet?
Ah, got it. I’ll try that, should work, the machine has internet access.
