Good Morning,
One of our corporate clients is struggling as they need to configure Yak to use a Proxy server - is this feasible?
David
Good Morning,
David
Hi David,
As of Rhino 7.27, the package manager in Rhino supports authenticated proxies. You should be able to run the _PackageManager
command and if it needs proxy credentials it will ask.
The package manager command line utility (yak.exe) doesn’t support authenticated proxies.
Thanks Will, is there any means to force the _packageManager command to use particular Proxy Credentials? This is the current behaviour on site. I will check which version they are running but i am fairly sure it is uptodate
yes confirmed this behaviour was with SR27 - how can i trigger the prompt for proxy server settings?
