How to flow on surface in grasshopper?
Hello Everyone!
I am a jeweller and I want to automatize a simple ring to take the size of my clients. I would like that the size is engraved on the ring, like on the picture.
I am very much a beginner in grasshopper therefore any help will be appreciated.
Thank you! :slight_smile:
RingMass.gh (17.0 KB)
You could use Splop.
RingMass_re.gh (17.0 KB)
Hello!:slight_smile: thanks for your answer, unfortunately, I still have rhino 5 and grasshopper 0.9.0076 and splop is not in my old version. :frowning:
Then, get Jackalope plugin fr food4rhino. That has the same feature.
https://www.food4rhino.com/app/jackalope
This got a lot messier than I expected. Using SrfMorph, which I believe works in R5?
RingMass_2020Dec25a.gh (23.5 KB)
The ‘Angle’ slider allows the engraving to be rotated ±360 degrees so it can cross the seam.
Thank You Kim And Joseph! in the meantime, I upgraded to Rhino 6 (And had to upgrade my Spacemouse software as well) Than you very much for your advice. I think this topic is solved :smiley:
Hi -
FWIW, if you just now upgraded to Rhino 6, you’ve been ripped off. Rhino 7 is out and the upgrade from Rhino 5 should have been to Rhino 7. All this assuming that you have actually paid anything for any of this…
