When it creates a section view using either a rectangle or a box, the red outline represents the rectangle I provided. However, it completely disregards it and proceeds to rotate it by 90 degrees.
[Furthermore, whether rotates the original rectangle or the rectangle generated from a plane, it remains unable to rectify the situation]
half solution A: “However, by using the endpoints of this red rectangle, you can regenerate the rectangle and give it to it, which allows you to control the angle of this section, but you cannot control the orientation (flip) of the section.
my question would be :
how to control the exact size of section frame and facing by provide a rectangle?
or how to flip a section in rhino inside revit, so i could still using half solution A to create a correct size of section frame, then using “flip” to gain both side section
I am using different plane to control the facing of the section, and use a bunch of rectangle to crop the responding section, but the result are kind of werid since it did not match the facing or crop shape as I provide in GH.
I am now using “View Crop Region”, it solve the problem above, but leading to another bug: some wall and structure which are cutted, did not shown in the section…
using plane as frame to create section: losing cutted object
using retangle as frame to create section: the crop area is not correct and facing could not control(when using rectangle represent correct facing and region, it will throw a bug:
