How to fix poor line quality display in V8 layouts
I don’t know if you will be able to see the difference in the images below…
V7
V8
This is a simple Make2D in V8 and then 1 detail Layout A4 horizontal. Everything else is default. I copy/pasted the result into V7 and did a layout there. In V8 I do have Testwirethicknessscale set to 1.5.
In V7, the lineweights are all consistent and pretty clean, I do detect a tiny bit of aliasing on the off-vertical lines in the Perspective view, but not too bad.
In V8, the result is thinner, the lineweights are inconsistent - some being much thicker than others, and there is a significant amount of aliasing on the off-vertical lines. Setting Testwirethicknessscale to 2 helps a bit, but there is still some inconsistency in the lineweights and the aliasing is still there - plus that’s too thick for my normal display.
I deliberately set curve width to pixels (3) in V8 to make the comparison with V7 where it’s also set to 3. It’s worse when I set it to “Use objects width” in V8 with my usual scale set at 1.5.
This is the first time I have been messing with layouts in V8 - any advice as to what can be done here?
In addition, in Make2D, the lineweights are set to “by layer” (Default) for normal curves and to “Default - by object” for hidden ones - this is more of a Make2D issue I guess.
Addendum:
I printed a layout to PDF from V8 and then printed the PDF on paper. The paper print looks pretty crisp actually. So this may be just a display issue?
Hi Mitch, it is easy to see. —-Mark
